96 VW Jetta 2.0 , 140K, engine stall
1996 VOLKSWAGEN
WALTER
  • 7 POSTS
Car started fine and drove 100yds and then stalled. Cranks but will not kick over.
Feb 1, 2007 at 2:43 AM
2CARPRO JACK
  • 11,533 POSTS
Got spark? Got fuel? check engine light on?
Feb 1, 2007 at 7:49 AM
WALTER
  • 7 POSTS
Yes- fuel. Yes- spark. No engine lite.
Feb 1, 2007 at 11:47 PM
2CARPRO JACK
  • 11,533 POSTS
Need to check for injector pulse.May have fuel pressure, but if injectors dont hit none gets in the engine
Feb 2, 2007 at 9:11 AM
WALTER
  • 7 POSTS
correction ! I have no spark.... Belts are fine , fuel is fine. Coil pac perhaps? It is expensive troubleshooting with new parts. Thanks
Feb 3, 2007 at 3:28 AM
2CARPRO JACK
  • 11,533 POSTS
I know it is,but if there is injector pulse then the PCM is seeing the engine turn and petty much leaves us with the coil pack
Feb 5, 2007 at 10:44 AM
WALTER
  • 7 POSTS
Thanks for the help.. Jack. It was the coil pack. It failed two times in 5 years. The mech that saw the car didn't do any electrical work- hence my open questions for which I had no answers. Thanks for narrowing it down (troubleshooting).
Feb 7, 2007 at 12:16 AM
