2004 Other Volkswagen Models ENGINE
2004 VOLKSWAGEN
67,000 MILES • 4 CYL • 2WD • MANUAL
WILFY27
I have a 2004 1.8turbo 180 bhp 6 speed vw bora . Its fully serviced and has 67000 miles on the clock . Recentlyi have heard a noise coming from the engine bay and the longer i drive it for , the louder it gets . Please help
Jul 27, 2009 at 5:16 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Can you give me some indication as to what sort of noise?
Mark (mhpautos)
Jul 27, 2009 at 6:08 AM
WILFY27
its just the general hum of the engine which gets louder and louder . sounds like a hole in the exhaust type of noise . also when in 2nd gear i sometimes get a drop in pressure from the turbo so when you feel the power its a noticable drop
Jul 27, 2009 at 6:34 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Best you check for an induction and exhaust leak, if this is affecting the boost i would be looking here first.
Mark (mhpautos)
Jul 27, 2009 at 6:56 AM
WILFY27
it would'nt be a timing belt problem would it
Jul 27, 2009 at 7:08 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
you could have a noisy tensioner bearing, but the drop in boost is in the back of my mind, to be safe get the timing belt check for wear and the bearings tested, or at least have a mechanic listen to this noise as a good mechanic will be able to pick the difference between exhaust ? induction noise & engine or bearing noise, on some turbo's if you have an induction leak after the turbo, this can sound like a noise like this, i had a similar noise with my turbo Discovery and found a crack in the inter cooler.
mark (mhpautos)
Jul 27, 2009 at 5:26 PM
