2001 VW Jetta GL - Automatic
2001 VOLKSWAGEN
VWDRIVER
The VW dealership is telling me that I need to have the 2nd air pump and hose replaced (the guy said its near falling off) and the rack and pinion steering fluid is leaking.
How much is something like this going to cost me?
Thanks :D
Jan 19, 2007 at 8:48 AM
BRUCE HUNT
  • 3,754 POSTS
He is talking about the secondary air pump that is part of the injection system. Access to it should not be that bad, but you way they are going to replace it? Why is it near falling off? Would re-tightening it not work?
On the rack, take a look yourself and see if it is a hose leaking or if it is a seal? Racks to replace are pretty pricey. The pump if it has indeed failed shouldn't be too bad.
I take it the car had problems and kicked out a check engine code.
Jan 19, 2007 at 9:23 AM
