1996 Jetta GL HORN NOT WORKING
1996 VOLKSWAGEN
KOOLMIKE500
  • 6 POSTS
HEY 2 CAR PROS,
I have a 96 Jetta GL 2.0 5 speed. A great car, resently I have lost my horn. I checked the fuse and I know its not that. Theres a high and a low tone which both need to be replaced. Can I use an aftermarket part? or should I check out a junk yard? or do I have to go to VW? thanks alot
Mike P> Lindsay [img:c890a58084]http://www.2carpros.com/forum/automotive_pictures/47119_DSCF0012_1.jpg[/img:c890a58084]Ontraio
Mar 10, 2007 at 7:26 PM
XGAN2002
  • 7 POSTS
i could check the wiring because in vw's they have two horns! one in the passenger finder and the other in the grill pop the stering wheel off and take a look at that or check the horn if all looks good then you could use a after market one but you would have to splice the wires into the new horn but if you go to vw then they will give u a stock replacement
Mar 15, 2007 at 2:26 PM
