1993 corrado vr6 slc 135000
1993 VOLKSWAGEN
BLAZERSLC
i have fuel in my oil. i dont seem to have a power loss sometimes is hard to start. it is well taken care of. if i change my oil and run it fuel will be in oil. it does burn oil to but i wonder if it is because the oil is so thin. what could be causing this
Jul 26, 2007 at 8:15 PM
BRUCE HUNT
  • 3,754 POSTS
I gathered this information from 2carprosJack.
The only place I can think of that fuel will get into the oil is from a blown fuel pressure regulator. Should be on the fuel rail with a vacuum line to the intake, remove it and check for raw fuel in the hose.
You are correct in thinking that the thinning of the oil is causing the burning of the oil. I hope things work out for you.
Jul 27, 2007 at 2:08 PM
