The fuel injector may be past repair, but the first thing to do before paying out high dollars for a mechanic is to run some fuel injector cleaner through the system. If the injector is clogged, this should clean it out. If it doesn't (or if you can't get it started to do so) , you can remove the injector yourself and clean it out with a very tiny tool of some sort to ensure it is not clogged.
I'm just curious. When was the last time you changed the oil? If the oil has broken down then there is nothing to keep the fuel/air from blowing past the rings into the crankcase. With your mileage, I would consider putting some ring restorer in it and change the oil.
Those are the only two ways, that I know of, that would cause fuel to get into the oil except manually putting it there.
Nov 9, 2008 at 2:29 PM
