I have been driving my car daily. A couple of weeks ago it started running rough. I replaced the fuel pump, the fuel filter and it didint help. I then replaced the coil and points and it was still running rough. It would idle fine for a little while, but would not run. I then replaced the carburetor. When I tried to start it then, I had very little spark coming from the coil. From another web site, it gave instructions how to check the coil with an ohm meter and it checked out within their limits. I tried running a hot wire from the battery to the coil, with no change from the spark to the coil. My questions is, what could be causing this? Any suggestions would be greatly appreciated.
Sep 23, 2007 at 10:01 PM
