Transmission problem
1969 Other Volkswagen Models 4 cyl Two Wheel Drive Manual unknow miles
I have rebuilt a 69 vw convertable and when i put the motor and trans together and got the motor running, runs good. When i try to shift to first from neutural the gears grind. If i stop the engine it shifts fine. I thought I had moved the adjusting nut on the clutch lever up but do i need to tuighten it more? My friend thinks it is the shifting tube has come loose and needs to be rewelded in the tube from the shifter to the trans.?
thank you for your time
Joseph
Colorado
Joseph
Colorado
Mar 10, 2008 at 11:30 PM
