Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Volkswagen
Jetta
Drivetrain
Transmission
Fluid
Transmission Fluid
VOLKSWAGEN JETTA
TAMMYPEAKE
MEMBER
1 POST
FOLLOW
How and where do I check the transmission fulid in a 1999 automatic 4 cyl. VW Jetta?
Jul 18, 2008 at 10:33 AM
KHLOW2008
CERTIFIED EXPERT
Hi tammypeake, You need to remove the ATF level plug.
Aug 4, 2008 at 8:53 AM
CHUTES333
MEMBER
What do the numbers in the picture stand for? If you pull the plug, won't the trans fluid come out? Thanks for any help
Jul 7, 2009 at 4:05 PM
KHLOW2008
CERTIFIED EXPERT
Hi chutes333,
1 is the plug.
2 is the level tube.
3, is filling tube.
4. is cap.
Removing the plug ( 1 ) would only allow excess fluid to flow out. To drain you need to remove level tube ( 2 ).
Item 4 has to be replaced if it is removed as it is locked.
Jul 8, 2009 at 8:37 AM
CHUTES333
MEMBER
Thanks for such a quick resonse. You saved me a big headache!!!!!
Jul 8, 2009 at 4:26 PM
KHLOW2008
CERTIFIED EXPERT
You are welcomed and glad to be of service.
Have a nice day and thanks for the feedback.
Jul 9, 2009 at 8:16 AM
