Brakes problem
2004 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic 80.000 miles
All new rotors / pads were installed and the system was bled. Almost full braking was achieved when the pedal pressed to the floor. During the second half of lifting the pedal up front caliper pistons retract maybe 0.3 mm each, I can see these gaps and can insert a paper sheet between the rotor and a pad. When I push the pedal a half way is spent to slose gaps back before it starts braking. Faster pushing or pumping does not change anything. Why I have partial vacuum inside the caliper which pulls the piston in?
Jul 20, 2009 at 7:19 PM
