have done compression test ,vacuum test, changed all injectors ,fuel pump ,fuel preasure regulator, vacuum valve , combi valve,fuel filter ,all coil packs ,spark plugs ,secondary air pump, fixed all vacuum and exhaust leaks I can find, and the first o2 sensor... have also changed out the maf sensor ...code still wont fix where can I go from here?
Aug 20, 2009 at 5:58 PM
