2002 Volkswagen Jetta Distributor cap
2002 VOLKSWAGEN JETTA
126,000 MILES • 4 CYL • FWD • MANUAL
CVLERCH
Every time it gets wet outside, my car simply won't start. I know the battery is charged, I have enough fuel etc. A friend told me to check the distributor cap to see if its cracked or not sealed right. Is that a good idea and if yes how do i do that?
Feb 11, 2010 at 9:48 AM
BOLTHOUSE
A 2002 Jetta doesn't use a distributor cap it uses a more advanced ignition system called a coil pack. (It's all electronic) I have already replaced mine on my 2001 Jetta GL. Water should not get inside it unless it is somehow cracked. It would probably misfire every so often if it was that sensitive to moisture. It must be an electrical system problem if the car is not making any noise. I would first check your battery terminals to see if you have corrision and the wiring system. It is around $140 for a new coil pack from the dealership plus labor. I have seen a testing module for $60-70, but I am unaware of anything else.
Feb 18, 2010 at 3:20 AM
