2001 Volkswagen Jetta Starts then dies in the morning.
2001 VOLKSWAGEN JETTA
95,000 MILES • 4 CYL • 2WD • MANUAL
CHEX
My 01 Jetta just developed this problem. In the morning is starts and then dies. Starts and then dies. I can usually give it a good rev, then it dies. Then later on it's fine. As of 6:30 PM I went to leave and it did it again. This is driving me nuts because I don't know what it could be. Maybe a partially clogged fuel filter? A fuel pump going bad?
Jul 26, 2009 at 5:37 PM
DUBTECH
  • 159 POSTS
Is the Immobilizer (small car icon) light flashing on the dash when this happens.
If so, you're key is going bad and the security system is not recognizing it.
Another possibility is a dirty throttle body. If it gets too dirty the computer won't be able to open it up enough to hold an idle. If this is the case it should be carefully cleaned and then the throttle body has to be adapted using a factory scan tool.
Jul 27, 2009 at 10:56 PM
CHEX
Ugh, so that means I would have to take it and get it professionally done. I can hear my wallet screaming already. Thanks though, because it seems to make sense about the throttle body as the throttle seems a little sluggish sometimes.
Jul 27, 2009 at 11:00 PM
DUBTECH
  • 159 POSTS
I think there is a trick out there to re-adapt the throttle body without a scan tool. I've always had access to a VAG scanner so I never needed to know.
Maybe a Google search for VW throttle body adaption will get an answer...
Good luck
Jul 27, 2009 at 11:07 PM
