2001 Volkswagen Jetta
2001 VOLKSWAGEN JETTA
100,000 MILES • 4 CYL • FWD • AUTOMATIC
BRIAN2008
hi
my friend has a jetta and for some reason it runs like junk only when its raining just put new plugs wires and air filter in it im stumped please help
Feb 13, 2008 at 10:25 PM
SCARLETT7773
I had the same problem with my 01 Jetta. It might be the coil pack. I just had my replaced for $432. It would run roughly when ever it rained and the check engine light would come on. When the coil pack is dry the problem would go away. There was a crack in the casing. Now I'm having trouble with my catalytic converter. Which I've read can be connected with driving a car with a bad coil pack. Don't wait to have it checked! If you search around on the net you'll find this is not unusual for Jettas.
Feb 18, 2008 at 6:48 PM
BRIAN2008
thanks for your input ill look into it
Feb 23, 2008 at 4:11 PM
