2000 Volkswagen Jetta replacing fuel relay switch
2000 VOLKSWAGEN JETTA
14,900 MILES • 4 CYL • FWD • AUTOMATIC
VAHAN
im having rough running engine problems, its seems like its not getting constant fuel flow, have a new fuel relay switch to instal as im pretty sure thats the problem( took it to vw dealer some time ago ,said its going out) however, i dont know where it gets replaced at or what tools to use.
help!
Mar 23, 2010 at 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump relay is on the relay panel, under left side of dash. just disconnect electrical connector to replace relay.
Mar 23, 2010 at 3:00 PM
VAHAN
thankyou for the indication of where fuel relay switch is located; however the rough running engine is a bad # 1 fuel injector problem.
they are separate problems. i appreciate your help nonetheless. thanks again,
V.
Mar 26, 2010 at 3:32 PM
