2000 Volkswagen Jetta Alternator Workshop warning
2000 VOLKSWAGEN JETTA
101,000 MILES • 6 CYL • 2WD • MANUAL
MM74
While driving my 2000 Jetta GLX last night the Generator, Brake, ABS and Anti-Slip regulation indicator lights suddenly came on and all the internal lighting went out. The engine was still running, the headlights remained lit and the radio was still on. The internal lighting came back on but all the indicator lights remained on. Fortunately, I wasn't far from home and arrived without any further incident. This morning I went out to start the car and the Alternator Workshop warning came on as well as the generator light and flashed at me to STOP, which I promptly did.
Just to give a little background info: I recently had the timing belt replaced (it busted on me due to a loose tensioner pin!). Also just got it back from the shop 2 days ago for routine maintenance (just turned 100,000), had some unrelated things replaced and they tested the battery, starter and alternator - all were fine. So here's my question - what the heck is going on with my Jetta?
Mar 9, 2008 at 9:02 PM
EXOVCDS
  • 1,883 POSTS
If it truly is a 6 cyl (VR6) engine, then there is NO timing belt
and most likely what was replaced is the Accessory Drive Belt that
runs the water pump, A/C, Alternator & Power Steering.
The VR6 engine uses Timing Chains that are located on the transmission
side of the engine.
Thomas
Mar 11, 2012 at 1:49 AM
