1999 Volkswagen Jetta Vibaration
1999 VOLKSWAGEN JETTA
BARRIAGA
Engine Performance problem
1999 Volkswagen Jetta 6 cyl Two Wheel Drive Automatic
I have had a vibration problem with my engine. Had it check, it was the supports (motor mount supports). About 2 and 1/2 months later it happened again, I was told it was a rod that also support the engine/motor that runs in the bottom and screws up - also acts like a support? Is there such a thing? and what is it called? I was told the only fix would be a new motor? Please help me.
May 4, 2010 at 4:45 PM
2 LINSEY
  • 287 POSTS
hi barriaga, Thanks for donating, Yes there is a motor mount that supports the bottom of your motor and its called a lower motot mounr, sometimes it is the transmission mount as well. Does the motor have any problems, how does it run? let me know
May 7, 2010 at 12:57 PM
BARRIAGA
Okay, the car runs. except at stopped it vibrates. However, I did find out that there is a rod that is some how connected to the chasis? and it acts like a support. so what has been replaced are the two motor mounts that act like cushions. But this other rod thing is getting me. I just don't know what to do. Thanks so much for your help.
May 7, 2010 at 8:35 PM
2 LINSEY
  • 287 POSTS
That rod thing is a motor mount as well. It is a different style of motor mount and could be the cause of your viberation. It supports the bottom of your engine.
May 10, 2010 at 12:06 PM
