1999 Volkswagen Jetta Speedometer/tachometer not working
1999 VOLKSWAGEN JETTA
127,000 MILES • 6 CYL • FWD • MANUAL
WBB71288
I have a 1999 , old body style, Jetta GLX VR6 w/ 2.8L and the speedometer and tachometer does not work most of the time. Could it be a bad relay and how do I check it out?
Apr 13, 2009 at 4:28 PM
LEGITIMATE007
  • 5,121 POSTS
more than likely its your vehicle speed sensor, but you will wanna check all fuses located near and around the steering column. Is there an engine light on?
Apr 13, 2009 at 4:44 PM
WBB71288
The check engine light is on but the auto zone checked it and said the code came up as an O2 sensor needed replacing. Where would I find the speed sensor?
Apr 13, 2009 at 5:20 PM
LEGITIMATE007
  • 5,121 POSTS
yes that is probably what is making your engine light come on and it does need to be replaced, but I can assure you that the o2 should not be what is causing the tachometer to go crazy like that, go ahead an replace that o2 and then take it from there
Apr 13, 2009 at 5:49 PM
WBB71288
Where would I find the speed sensor? (on the car)
Apr 13, 2009 at 8:09 PM
LEGITIMATE007
  • 5,121 POSTS
it would be either ontop of the transmission or on the side.
Apr 14, 2009 at 2:36 PM
