1999 Volkswagen Jetta Ignition Coil
1999 VOLKSWAGEN JETTA
LORENZOA
Electrical problem
1999 Volkswagen Jetta 4 cyl Two Wheel Drive Manual
My 1999 Jetta frequently stalls on the freeway, the last time this happen I disconnected the number 4 spark plug wire and connect a spare plug plug and had a friend crank the engine. There was no spark. After about an hour, the car started up and I was able to drive it home. Any idea what may cause this and is it something that could be identified by a computer code reader. Ther check engine light comes on after the car starts but it soon goes away.
Aug 14, 2008 at 2:47 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
get the code reader and see if you have any set fault codes, i would be looking for a cam or crank angle sensor fault.
mark (mhpautos)
Aug 15, 2008 at 5:35 AM
LORENZOA
I check the code reader and there isn't anything else going wrong with it. I did notice that there is 12 volts going into the coil pack during the stalling event but no spark coming out of the coil.
Aug 15, 2008 at 3:28 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would think that if you have no fixed fault codes that the coil pack may be faulty and causing a short when it over heats, may be see if you can get hold of a good second hand coil to try this theory out, as to start to do a full electrical diagnose is a major undertaking,
Try this next.
mark (mhpautos)
Aug 16, 2008 at 4:20 AM
