1998 Volkswagen Jetta Timing Belt OR Transmission
1998 VOLKSWAGEN JETTA
138,000 MILES • 4 CYL • FWD • AUTOMATIC
THABAKERSMAN
Whats going on..i have an automatic volks, jetta.. 1998.5 version ..when im in reverse it takes a second or two to kick into gear then it works perfect.. sometimes but not often, when first starting the car.. first gear slips..
ive been told twice that it could be a loose or weak timing belt (if that goes, my whole engines done)..ive been told my transmissions going .and a fluid change will only make it worse. though ive also been told if i get a new tranny fluid filter with a change my car should run perfect..
im not sure what it could be for sure and would like some help. .thanks in advance.
Jun 10, 2009 at 12:49 AM
BMRFIXIT
  • 19,053 POSTS
With the mileage that you have ,timing belt for sure need to be checked and replaced as if it brake internal engine damage will occur
I do not believe the timing belt is the cause of the tranny issue
and transmission need to be checked for sure
new fluid should help if any and not make the matter worse
good luck
Jun 10, 2009 at 6:36 AM
