Engine Mechanical problem
1998 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic
OK, so... i have this really weird problem going on. First of all last year i had really bad idle, it turn out that the throttle body went bad. I got a new one, did adaptation. When i test drove it, it was fine until it got at its normal temperature. I noticed that the idle didnt went all the way down to were it suppose to be at. I put it in Park and the noticed that the idle needle started to act a little bit crazy because it went up to 1400 RPMs and it like misfired, then went down to 800 and so on. Then i got this code P0341 which is the cam sensor. That got replaced last year also, the timing is aligned properly. Could it be a bad distributor cap or rotor? Thanks
Jan 18, 2010 at 4:50 PM
