1998 Volkswagen Jetta Alternator
1998 VOLKSWAGEN JETTA
98,000 MILES • 6 CYL • FWD • MANUAL
CRISDEGREE
The alternator went bad on the car so i replaced it with a refurbished OEM from the local parts wharehouse. After install i i checked voltage supply at the battery while running and the alternator was not charging the battery (12.8 and dropping) i exchanged it for another one and installed it again. same thing happend with the exchanged one but this time the alternatorr was whining very loud. I check output directly at the B+ terminal on the alt. while the engine was running on battery power. No voltage reading at all. what am i doing wrong? any ideas? could i just be that unlucky and i got 2 bad alternators?
Aug 30, 2008 at 7:39 PM
TIGERBREEZE
The same thing is happening to me! I've gone through 3 alternators and 2 batteries. My cables look fine too.... Have you figured it out yet?
Oct 2, 2008 at 11:39 AM
GABRIELJORGE1
I have the same car and the same problem, what can I do?[quote:4fda4a1cb7="crisdegree"]Electrical problem
1998 Volkswagen Jetta 6 cyl Front Wheel Drive Manual 98000 miles
The alternator went bad on the car so i replaced it with a refurbished OEM from the local parts wharehouse. After install i i checked voltage supply at the battery while running and the alternator was not charging the battery (12.8 and dropping) i exchanged it for another one and installed it again. same thing happend with the exchanged one but this time the alternatorr was whining very loud. I check output directly at the B+ terminal on the alt. while the engine was running on battery power. No voltage reading at all. what am i doing wrong? any ideas? could i just be that unlucky and i got 2 bad alternators?[/quote:4fda4a1cb7]
Jul 31, 2009 at 11:46 PM
