1998 Volkswagen Jetta
1998 VOLKSWAGEN JETTA
JEREMY1876
Engine Performance problem
1998 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
98 jetta 2.0 l
idles between 400-600
when driven bucks sputters
changed plugs, wires, cap, button, fuel filter
fuel pump sounds like it is working
Jul 16, 2008 at 1:30 PM
KHLOW2008
  • 41,814 POSTS
Hi jeremy1876,
You got the electrical covered, so should check the injectors, could be loose wires.
Idling is rather low, is the engine running smooth?
Is the CEL showing?
Jul 17, 2008 at 2:02 PM
JEREMY1876
CEL not on.
other than idle low, runs smooth when foot on gas.
before you shift from 2nd to 3rd, acts like fuel cuts out, both doesn't shut off. pump gas and and starts working again for awhile.
Jul 18, 2008 at 4:45 PM
KHLOW2008
  • 41,814 POSTS
Hi jeremy1876,
Symptoms looks like fuel is insufficient. Test fuel pressure, regulators and injectors.
Jul 19, 2008 at 10:40 AM
