1997 Volkswagen Jetta washer motor
1997 VOLKSWAGEN JETTA
BILLNAS
Electrical problem
1997 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
my wipers work but the washer will nor dispense fluid. when I depress lever the motor make no sound. Is there a seprate fuse.If I have to replace the pump does the battery have to be removed.
Thanks
Bill
Jul 13, 2009 at 5:22 PM
STEVEW84
  • 673 POSTS
The washer pump is located on the side of the washer fluid reservoir. You need to test to see if you are getting a power and ground to your washer pump when you turn it on.
Jul 16, 2009 at 7:04 AM
