1997 Volkswagen Jetta How to take a water pump apart?
1997 VOLKSWAGEN JETTA
116,000 MILES • 4 CYL • 2WD • MANUAL
SEBASTIAN_PERSONAL
  • 77 POSTS
I been trying to figure out, how to take the water pump apart. I got the alternator out as well as the belt out. I don't seem to figure out how to take the water pump out. It has some kind a black plastic shield that blocks me from accessing some part of the screws/bolts that holds the water pump.
I pull some part of the enjine block out but the water pump is still attached due to some of the few screws that is still left behind that is underneath the black plastic shield or (somekind) and behind the timing belt as well.
My friends said, that it is important not to take the timing belt apart or it will damage the motor. So If I can't take the black plastic shield and the timing belt out, then, what access do I have to take the remaining bolts and screws from the water pump?
Mar 22, 2010 at 9:58 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated You will have to remove the timing belt covers and timing belt to remove the pump from engine ! Coolant pump, disassembling and assembling The following list pertains to Fig. 3 . - 20 Nm (15 ft lb) - Coolant pump pulley For ribbed belt - Coolant pump Check that shaft rotates smoothly - Gasket Always replace - Thermostat To check, heat in water Starts to open at approx. 87 °C (188 °F) Fully open at approx. 102 °C (215 °F) Opening stroke: 7 mm (0.28 in.) minimum - Connector Pipe - O ring Always replace - Clip - 10 Nm (7 ft lb) - Flange - Coolant pump pulley For V-belt Removing and installing, use VAG 1590 Fig. 3: Exploded View Of Coolant Pump
https://www.2carpros.com/forum/automotive_pictures/266999_vw_1.jpg
Toothed belt, removing, installing, adjusting tension CAUTION:To prevent damage to valves and piston crowns while the toothed belt is removed, do not turn camshaft when crankshaft is at Top Dead Center (TDC). Removing Remove ribbed belt, and remove tensioner for ribbed belt if applicable, see RIBBED BELT, REMOVING AND INSTALLING. Remove crankshaft vibration damper/pulley. Remove coolant pump pulley. Remove upper and lower parts of toothed belt guard. Mark running direction on toothed belt. Loosen toothed belt tensioner and remove toothed belt. Installing NOTE:For repairs that require removing the toothed belt from the camshaft sprocket only, such as when removing the camshaft or cylinder head, see SEALING FLANGE AND PRESSURE PLATE/DRIVEPLATE, REMOVING AND INSTALLING. For repairs that require completely removing the toothed belt, such as when it is being replaced, install and adjust the toothed belt as described as follows. CAUTION:Before turning the camshaft, make sure that the pistons are NOT at Top Dead Center (TDC). With the toothed belt removed there is danger of damaging the valves and piston crowns. Align marking on camshaft sprocket with marking on cylinder head cover or toothed belt guard. Fig. 21: Aligning Marking On Camshaft Sprocket With Marking On Cylinder Head Cover Or Toothed Belt Guard Install toothed belt on crankshaft toothed belt sprocket and intermediate shaft toothed belt sprocket (note running direction when installing a used belt). Mount crankshaft vibration damper/pulley with at least one bolt (note installation position, holes are offset). Align mark on crankshaft vibration damper/pulley with mark on intermediate shaft sprocket (cylinder 1 set to TDC). Fig. 22: Aligning Mark On Crankshaft Vibration Damper/Pulley With Mark On Intermediate Shaft Sprocket (Cylinder 1 Set To TDC) Install toothed belt on tensioner and camshaft toothed belt sprocket. Increase tension on toothed belt tension by turning tensioner pulley with spanner 2587 in direction of -arrow-. It must be possible to twist toothed belt by 90 degrees with thumb and forefinger half-way between camshaft and intermediate shaft toothed belt sprockets. See Fig. 23. Fig. 23: Checking Toothed Belt Tension By Twisting Toothed Belt By 90 Degrees Tighten lock nut on belt tensioner. Tightening torque: 45 Nm (33 ft lb) Turn crankshaft through two complete revolutions, and check belt tension. Remove crankshaft vibration damper/pulley. Install lower toothed belt guard. Install coolant pump pulley, crankshaft vibration damper/pulley and upper toothed belt guard. Install tensioner for ribbed belt, if applicable. Tightening torque: 20 Nm (15 ft lb) Install ribbed belt RIBBED BELT, REMOVING AND INSTALLING.
Mar 23, 2010 at 3:45 PM
SEBASTIAN_PERSONAL
  • 77 POSTS
You mention that the timing belt has to be removed. I have removed the water pump out of the vehicle and have replace a new one without even taken out the timing belt apart. The only problem I have now is that, I have accidently turn the timing belt and the metal wheel where the belt goes around.
This accur during before I have taken out the water pump.
I have assemble all the pump together. Now it wont even start. Everytime I crank the enjine, it clicks and then the alarm comes on. I might have screwed up the timing. Is there any solution for me to fixed it back up?
Thanks,
Mar 25, 2010 at 12:08 AM
DAVE H
  • 13,384 POSTS
If you did not remove the belt or any of the belt's pulley's then the timing should not have moved .. unless you managed to somehow move the crankshaft or camshaft without actually moving the belt as well ? you need to check the timing marks are still aligned correctly From this diagram could you tell me which pulley you turned and did the belt and pulley turn together at the same time ?
https://www.2carpros.com/forum/automotive_pictures/266999_jet_2.jpg
let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1090.png
Mar 25, 2010 at 4:33 AM
SEBASTIAN_PERSONAL
  • 77 POSTS
thanks for the respond. the photo you sent, didnt realy show, but the 2 belt that i removed was the small belt tha goes from the water pump and a large belt the goes from the alternator. the belt that i didnt removed and accidently shift was the belt that is underneath the black plastic cover at the side of the motor. what is my next step to fixed the problem? thank you soo much.
Mar 25, 2010 at 9:41 AM
DAVE H
  • 13,384 POSTS
The belt behind the black cover is the timing belt .. if you didn't remove it .. and moved it, the pulleys .. (camshaft and crankshaft)should have all turned with the belt so the timing should not be out !!
Mar 29, 2010 at 6:34 PM
