1996 Volkswagen Jetta no spark
1996 VOLKSWAGEN JETTA
AFILIO
  • 4 POSTS
Electrical problem
1996 Volkswagen Jetta 4 cyl Front Wheel Drive Manual 150k miles
96 jetta has no spark . it started when a mtech replaced the cyl head gasket and the it didnt start , he said it was the ecm so he replaced the ecm and worked fine for 1 day then again no spark , he said it needs another ecm . i said sure ill got to the market and buy 2 ecms so he can play . HELPPPPP
Jul 2, 2009 at 8:35 AM
RACEFAN966
  • 5,029 POSTS
OK so did you check to make sure no wires got pinched when the head was put back on? Did all the electrical grounds get but back in place? Did everything get pluged back in? Let me know what you can and we will go from there.
Jul 2, 2009 at 9:43 AM
AFILIO
  • 4 POSTS
ok i spoke with my friend and he said that evrything started when he lost his keys and had another key made , then the car didnt crank so he installed a starter button , , now my question is how do i bypass the antitheft computer?
Jul 3, 2009 at 11:18 AM
RACEFAN966
  • 5,029 POSTS
Ok you need to get the right key and have it programed to accept that key and put it back to being right. There is no real easy way to bypass an alarm system as it tied into the system.
Jul 6, 2009 at 1:07 PM
AFILIO
  • 4 POSTS
ok but the thing is that this guy said the key is a regular key and that it was working fine for some time
Jul 6, 2009 at 1:28 PM
RACEFAN966
  • 5,029 POSTS
then something must have gotten disconnected.
Jul 6, 2009 at 1:39 PM
