1996 Volkswagen Jetta dies when throttle is applied
1996 VOLKSWAGEN JETTA
158,000 MILES • 4 CYL • 2WD • MANUAL
TIREBACON
My 96 jetta will start and the engine runs really rough at idle as soon as any throttle is applied it will stall out immediantly. When it broke down i replaced the coil pack and was able to drive it home but could smell the catalytic converter (smells like rotten eggs). The next day i tried to start it and had almost the same symtoms as before i replaced the coil but engine is running even worse and dies seconds after starting it.
Sep 19, 2010 at 1:57 PM
WRENCHTECH
  • 20,761 POSTS
Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Oct 29, 2010 at 3:32 PM
