Im confused does your car crank over or not ??
if it doesnt and you just get a clicking sound when you turn your key .. 99% of the times its a starter or starter solenoid problem ..
You can test your starter by raping it with a hammer ( Not Hard though ) !
but rap it softly while trying to start your car if you get a slugish crank its a starter problem ..
first id check your solinoide by hooking a multimeter or test light upto your engine ground and your starter solenoid trigger terminal ..
as seen here ..
https://www.2carpros.com/first_things/car_will_not_crank.htm
but yeah your test light should illuminate or you should get a reading on your multimeter ..
also check your battery terminals with a multimeter .. should read 12.6 volts .. meaning you have a solid connection and its not a battery problem .. if you have a shitty read check your terminals for gunk build up in them clean any gunk ..
** If your car is cranking over but it wont start..
few suggestions are to check your oil levels .. if there low refill but becarful not to overfill or you could damage your catiyitic something or other i forget the name im a little tired .. blah .. but yeah when your oil levels are low to none your car will turn over w/o starting ..
also try, sometimes in my jetta i have to turn my headlights on and pump the gas 4-5 times and hold the gas in and then try starting it ..
ohh Disclamier ** Defently not a professional ..
im just trying to help with my own past exsperiances ..
=D i hope i helped !!
Dec 12, 2018 at 10:13 AM
