1995 Volkswagen Jetta Oil Leaking from Air Cleaner Box
1995 VOLKSWAGEN JETTA
224,000 MILES • 4 CYL • FWD • AUTOMATIC
GAPUZZZ
We have oil leaking from air cleaner box. Car is 14 years old and has 220K but its a preey good amount of oil. Have been told before that PCV valve gets clogged. Would this be the issue. Husband says its just because it sits and is only driven short distances 2 or 3 days a week. We had all gaskets changed about 5 years ago. Any suggestions or known issues. Thank you.
Jul 22, 2009 at 11:41 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This is oil carried into the air box normally due to excessive crank case pressure, check the PCV valve and have a leak down test done to check blow by levels.
Mark (mhpautos)
Jul 23, 2009 at 1:19 AM
