1995 Volkswagen Jetta Car takes a while to turn on
1995 VOLKSWAGEN JETTA
DLFO1
Transmission problem
1995 Volkswagen Jetta Automatic
Every morning I try to turn on the car it usually turns on about the six time. We used to have an old battery that would die because it didn't charge fully. So I thought that was the problem and now I replaced the battery but it also turns on like on the fith time but at least the battery doesn't die. The speed metter doesn't work and the engine makes a high pitch noise when ever you press the gass n it starts to built Speed. A friend told me that the transmission is bad. Is he right or is it some other problem?
Aug 22, 2009 at 4:20 PM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
Does it make the noise even in park if you accelerate?
Aug 22, 2009 at 5:14 PM
DLFO1
No but it does it when I turn it on as the engen turns on
Aug 22, 2009 at 6:29 PM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
the high pitch noise sounds like a vaccum leak but i would think it would cause car to miss a lil bit. let me do some checking
Aug 22, 2009 at 6:36 PM
