1994 Volkswagen Jetta WindShield wiper problems
1994 VOLKSWAGEN JETTA
ESP80
1994 Volkswagen Jetta 4 cyl Two Wheel Drive Manual
My wipers only work at one speed(fast), a problem that I,ve had for a while. Also when I turn them off they do not go back to the bottom. I have recently failed inspection because of this and I was curious if you guys had any idea what would cause this problem.
Thank you,
Sep 5, 2008 at 11:52 AM
BMRFIXIT
  • 19,053 POSTS
would suspect the wiper motor
unplug it and have a helper go through the switch position for u as u checking for power 1st at the plug
if the power moves from wire to wire with the switch position changing
sure motor no good
good luck
Sep 5, 2008 at 1:29 PM
