1991 Volkswagen Jetta fuel pump fuse keeps blowing
1991 VOLKSWAGEN JETTA
145,000 MILES • 4 CYL • FWD • MANUAL
JKK2049
  • 47 POSTS
i hAVE A 1991 VW jetta gli.....one day as i was driving along my car stopped running....come to find out it was the fuel pump fuse hade blown....i bought a box of them and kept putting them in...everytime i would turn the key the fuse would blow...i figured there was a short somewhere...so i removed apart of my dash on the bottom to easier access the fuse box..i put the last fuse in the box in and it started right up...three days later it blew again i put another one in and kept driving along..3 more days and it blew again but this repeatedly kept blowing....this keeps happening and i cant figure it out...is my fuel pump slowly going bad?....someone please help...thank you
Aug 11, 2009 at 12:53 PM
DOCFIXIT
  • 18,828 POSTS
Bingo fuel pump or by stock in Buss fuse
Aug 11, 2009 at 1:14 PM
JKK2049
  • 47 POSTS
so more than likely its the fuel pump? and ive been using buss fuses...and thank you so so very much..
Aug 11, 2009 at 2:01 PM
DOCFIXIT
  • 18,828 POSTS
Before you rip it out ohm check wiring ie power wire to ground in case insulation has chaffed offf somewhere.
Aug 11, 2009 at 2:13 PM
JKK2049
  • 47 POSTS
ok i will check the ohms how many ohms should it be?..and with this car it has 2 fuel pumps an electric transfer fuel pump in the tank and an electric fuel pump outside the tank....which one should i replace? than for all ur help
Aug 11, 2009 at 3:00 PM
