My 2002 GTI 1.8T is leaking oil from the engine, I thaught it might have been leaking from the oil pan gasket, due to the fact that I wiped the pan down and watched the oil seap along the seal.
I replaced the oil pan gasket and placed silicone underneath just as an extra seal. well not 10 min after changing the gasket it started leaking again.
I know its not the oil pan, it looks like its comming from the right hand sinde right above the oil pan. I think its the crank pully, it is a side engine so im guessing its called the forward main seal.
now if it is that how do i replace it, I need to be pointed in the right direction with detailed instructions as I am very new to the car repair game.
if anyone can help I would greatly appreciate it. Even if you could send me to the right web side inorder to fix this problem.
Thanks a bunch
Thanks a bunch
Aug 25, 2009 at 5:41 PM
