The stick shifter is very difficult to move around, even in the neutral position it is very stiff and "sticky". The transmission does not grind at all and once you get the shifter in gear they all work fine. It is very difficult to depress the shift lever and put the car in reverse. First gear is tough as well.
I drove another 2001 GTI and the shift lever was like butter and flopped around in neutral as it should.
Seems and feels like it needs lubrication or adusting.
What could be the issue?
Apr 8, 2010 at 9:21 PM
