Switch off ignition
Insert flat screwdriver in lower partition between panel and grip recess
Unclip grip recess upward out of door trim, do not reach into grip depression while doing so, to prevent damage to brace
Press locking lug against connector and pull off
Unscrew seven bolts
Unclip door trim at the sides using disassembly pliers (SST 3392)
Lift door trim upward out of window recess
Unclip cable guide using a flat screwdriver, pull out bracket and unhook cable hook
Disconnect connectors
Jun 22, 2009 at 10:22 AM
