starter motor not turning?
1999 VOLKSWAGEN GOLF
PIERRE1113
We have replaced the battery and starter motor but its not turning.
Jan 11, 2009 at 10:01 AM
SQM
  • 6,383 POSTS
You could have a inoperative starter due to a faulty relay, wiring or bad starter motor.
https://www.2carpros.com/articles/starter-not-working-repair
First check the relay. It is located under the hood fuse block (see diagram).
Visually check for corrosion and burnt pin(s).
You can also test the relay:
Also check the wire that attaches to the starter and make sure it is secured. A loose wire can trigger no start.
If you have a good relay and good connection then it is likely a bad starter.
Thank you.
Aug 24, 2021 at 10:30 AM
