1997 Volkswagen Golf Driver's Side Headlight Bulb Repalceme
1997 VOLKSWAGEN GOLF
155,000 MILES • 4 CYL • FWD • MANUAL
THEMAK
I need help replacing the bulb on driver's side headlight.
Dec 18, 2009 at 7:07 PM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you do you have the single bulb or two bulb headlight system.
Dec 18, 2009 at 8:31 PM
THEMAK
It's a single bulb system.
Dec 18, 2009 at 9:12 PM
IMPALASS
  • 3,112 POSTS
Hello The information you requested. Headlight bulb, removing and installing Fig. 6: Removing & Installing Headlight Bulb (Golf & Jetta)
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_100.jpg
Removing o Remove tie-wrap (if installed) from headlight connector. o Remove headlight connector. o Twist bulb holder lock ring counter-clockwise approx. 1/4 turn and remove. o Pull bulb holder from headlight housing and remove bulb from socket. Installing NOTE: Do not touch bulb glass with bare fingers. Skin oil will evaporate when bulb gets hot, dulling reflector and/or damaging bulb. o Insert new bulb into holder. o Align lugs on bulb holder with grooves in reflector housing and install holder into housing. o Install bulb holder lock ring and twist 1/4 turn clockwise to lock. o Install headlight connector and new tie-wrap. o Check headlight aim.
Dec 18, 2009 at 10:36 PM
