1996 Volkswagen Golf oil pan
1996 VOLKSWAGEN GOLF
198,000 MILES • 4 CYL • FWD • MANUAL
CROWD
  • 9 POSTS
hi im tring to take off my oil pan rigth now and all the screw ar out if theres hidden one i dont know it juste dont want to comme down do i need to take off extra things out ??
or i need to stik a flat screw driver on the side to take it out im i gana damage anything ?
thank you for your help :)
chris...
Dec 22, 2009 at 10:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what engine size? 1.8L, 1.9L etc..?
Dec 22, 2009 at 12:42 PM
CROWD
  • 9 POSTS
[quote:17a64b4666="bluelightnin6"]what engine size? 1.8L, 1.9L etc..?[/quote:17a64b4666]
1.8L
Dec 22, 2009 at 1:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have you removed the bolts at the flywheel side of the engine? They are pretty hard to get to so many people seem to miss them. if you got those bolts then you may have to lower the subframe to allow the pan to drop
Dec 22, 2009 at 1:43 PM
CROWD
  • 9 POSTS
yes i took out thos 2 bolts neer the flying disk
the pan dont want to move and i dont know nothing about lower the subframe :S
i can put pics on if you want to see
thx..
Dec 22, 2009 at 1:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the stabilizer bar..this should let pan drop down. would you like stabilizer bar removal steps?
Dec 22, 2009 at 2:03 PM
CROWD
  • 9 POSTS
that will be awsom yeah i want it
thks alot :D
Dec 22, 2009 at 2:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable. Raise the front of the vehicle and support it with jackstands. Remove the front wheels. Remove the bolts/nuts securing the outer ends of the sway bar, then remove the bolts/nuts securing the brackets. Remove the sway bar. To install: Position the sway bar in the vehicle. Install the bolts/nuts securing the brackets. Tighten them until just snug (they will be fully tightened later). Install the bolts/nuts securing the outer ends of the sway bar. Tighten until just snug (they will be fully tightened later). NOTE On Golf and Jetta models, the collars of the washers face away from the bushings. The conical side of the bushings face the washers. Install the wheels, then lower the vehicle. Bounce the vehicle several times and allow the vehicle to stabilize. On Jetta and Golf models, tighten the bolts/nuts to 18 ft. lbs. (25 Nm). On other models, tighten the bolts/nuts to 15 ft. lbs. (20 Nm). Connect the battery cable.
https://www.2carpros.com/forum/automotive_pictures/261618_1_87.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_74.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_3_32.jpg
Dec 22, 2009 at 2:13 PM
CROWD
  • 9 POSTS
thx alot for the help but the pan wont move at all do i need to hit it or somting??
Dec 22, 2009 at 2:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the gasket is probably stuck from heat holding it on, yes try using a rubber mallet to budge it loose.
Dec 22, 2009 at 2:56 PM
CROWD
  • 9 POSTS
eee dud i dont have that smal black bar under my car il take pics end send you
Dec 22, 2009 at 3:25 PM
CROWD
  • 9 POSTS
thers no bar under my oil pan well juste a smal one bu theres a liquid in it duno wat wen it will blow il know after :)
https://www.2carpros.com/forum/automotive_pictures/452376_char_0701_1.jpg
https://www.2carpros.com/forum/automotive_pictures/452376_char_0721_1.jpg
Dec 22, 2009 at 3:44 PM
