1996 Volkswagen Golf help
1996 VOLKSWAGEN GOLF
130,000 MILES • 4 CYL • 2WD • MANUAL
ZACHIAS22
when i first get in its cold but not ice cold then it gets real hot like the heat is on.
then again i do live in a hot place so that doesnt help either
Aug 23, 2009 at 12:42 AM
DUBTECH
  • 159 POSTS
I think you are referring to the Air conditioning system, but not clear. Can you please elaborate on your problem and concerns.
Aug 24, 2009 at 9:55 PM
ZACHIAS22
yeah the a/c my bad. i dont know if its jus freon.
im tryin to pinpoint the prob. is there a known way to tast the a/c systems parts??
condensor,etc.....
Aug 25, 2009 at 8:49 AM
DUBTECH
  • 159 POSTS
The first step is to put a set of pressure gauges on it. The high/low side pressure readings will tell a lot about how the system is working.
If the freon is low, you'll need to find out why. That's when you'll need some sort of leak detection equipment.
Aug 25, 2009 at 1:49 PM
