1996 Volkswagen Golf go to crank engine no crank
1996 VOLKSWAGEN GOLF
96,000 MILES • 4 CYL • FWD • AUTOMATIC
KENTUCKYVW
When I go to crank the engine, I turn the ignition switch with the key and all the instrument panel lights come on and the day running lights come on too. When I then go to crank the engine with the ignition key the day running lights go out and the engine does absolutely nothing no crank or chatter nothing.
Apr 6, 2008 at 6:45 PM
MIKE H R
  • 3,094 POSTS
check the starter, it could have a dead short that when tried to start puts a drain on the battery
Apr 7, 2008 at 9:03 AM
2CARPRO JACK
  • 11,533 POSTS
Be sure all battey connections are clean and tight.Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced.
Apr 8, 2008 at 8:09 AM
