1996 Volkswagen Golf Engine Alarm/Oil light Randomly Activa
1996 VOLKSWAGEN GOLF
AHOPF
Computer problem
1996 Volkswagen Golf 4 cyl Front Wheel Drive Manual 100K miles
The problem I am having with my car is the Oil light flashes and the engine alarm keeps going off after I drive the car for a few minutes. The interesting thing is there is plenty of oil and it is at the proper temperature when it goes off. I took the wires on the oil senders and this did not remedy the problem. Also, when I turn off the car, then turn it back on again, this remedies the problem for a few minutes and then it will start up again. The problem never occurs right when I turn the car on, only after it has been running. The strange thing is the car continues to run correctly, and I keep driving, with no hiccups whatsoever. It used to happen every few months, but now it happens much more often. I am in school right now so I only drive the car occasionally because it is at my parents house. Please help me figure out what is going on.
May 3, 2008 at 3:22 PM
JB166
  • 5 POSTS
you got to empty the oil and the sump to reset the senor did it mine stop the dam beeping make sure you don't over fill blocks the sender then starts to bleep pain in the arse good luck
happy hunting jb166
May 13, 2008 at 6:05 PM
NEVER_BACK_DOWN
i have just recently done my oil change!!!!! Does this mean that I have to re-do the oil change to reset the bleep?
Jul 27, 2008 at 4:59 PM
JOSE VILLA
It might happen when oil density is too thin for you engine. It happend to me when I tried synthetic oil in my 70k mile engine. I changed the synthetic oil to a regular 15-50 multigrade oil and the problem went away. Good luck,
Jose
Oct 7, 2008 at 8:09 AM
