1995 Volkswagen Golf distributor
1995 VOLKSWAGEN GOLF
15,000 MILES • 4 CYL • FWD • MANUAL
FEVERINSIIDETHESTORM
i replaced a motor in a 95 golf and i had to use the old ditributor cause the other one didnt have on...so i think the timing is off.how do i fix this on these cars
Jul 11, 2008 at 5:33 PM
KHLOW2008
  • 41,814 POSTS
Hi feverinsiidethestorm,
You need to get the static timing of the distributor correct.
Turn engine to No 1 cylinder at TDC on compression stroke, ie, with valves opening overlapping on Cylinder 4.
Refer to mark on distributor for No 1 firing and plug distributor in. After distributor is seated, rotor should be pointing at No 1 wire point on cap.
Jul 18, 2008 at 1:39 AM
