1994 Volkswagen Golf Front window screen wipers
1994 VOLKSWAGEN GOLF
RAF64
Electrical problem
1994 Volkswagen Golf 4 cyl Front Wheel Drive Manual
HI, my front wipers only works on the fastest setting but now and again it works fine, I think there is a loose conection somewhere but I don't know where to find it. can you help?
Jul 11, 2008 at 11:42 AM
KHLOW2008
  • 41,814 POSTS
Hi raf64.
Intermittent problems are always hard to diagnose and I can only give you some suggestions.
Check the wiper motor for loose connections of wire sockets. Check its ground wire.
Test the motor when it does not work.
Check the relays and fuse for bad or burnt contacts..
Jul 18, 2008 at 1:46 AM
