Our ignition lock cylinder appears to have failed. To remove the screws seem to be a specialty 3 pronged head which I am unfamiliar with. Does anyone know what type of tool I need to remove the screws? Secondly, the black plastic rim around the key insert cylinder has what appears to be an electrical connection attached. Is this removable? If so what is preferred method?
Thank you.
Thank you.
Sep 17, 2009 at 11:27 AM
