2001 Volkswagen Beetle LIGHT CHANGE
2001 VOLKSWAGEN BEETLE
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
GDMLM
How do you change the lightbulb for headlight? We've tried everything. The high beams work, but the low beam is out on left headlight.
Jul 15, 2009 at 7:26 AM
STEVEW84
  • 673 POSTS
There is a lever that you have to pull all the way and the headlight will slide out. If you have never done one then it is a bit of a PITA. My recommendation is to try to clean and lube the slides or take it to a shop.
Jul 16, 2009 at 11:59 AM
