The car seems to stumble after starting when the engine is cold, aaafter the car warms up it runs smoothly. What could be the matter?
Nov 1, 2008 at 1:00 PM
MARKA54913
MEMBER
1 POST
First of all, is the check engine light on? The cheapest and likely guess on a volkswagen is the coolant temperature sensor, which should be under $10.00 at the dealership. Any parts store should have the same sensor in stock, just make sure to get a new o-ring and clip. (or don't lose your originals, pray for no leaks.)
Also, pull the engine cover off and inspect the vacuum lines off of the intake manifold and fuel pressure regulator.
