Hi iam1jones,
Here are the procedures.
Brake pads, removing and installing
Removing
â—¦ Remove wheels.
â—¦ Remove cover caps.
â—¦ Disconnect connector - 1 - on vehicles with brake pad wear indicator (left side).
â—¦ Remove both guide pins - arrows - from brake caliper.
â—¦ Remove brake caliper housing and secure with wire so that the weight of the brake caliper does not stress or damage the brake hose.
â—¦ Remove brake pads from brake caliper housing.
Only use methylated spirit for cleaning the brake caliper housing.
Installing
NOTE:
"¢ Press piston back in the cylinder with piston resetting tool before installing new pads. Before pressing the piston back, draw off brake fluid from brake fluid reservoir using a bleeder bottle. Otherwise, if the reservoir has been topped off, fluid will overflow and cause damage.
â—¦ Pressing piston back.
â—¦ Insert inner brake pad (piston side) - 1 - and outer brake pad - 2 - in brake caliper housing
with retaining springs.
"¢ Inner brake pad (piston side) with large 3 finger clip - 1 - .
"¢ Outer brake pad with small 3 finger clip - 2 - (black).
â—¦ Insert brake pad with black 3 finger clip into brake caliper housing.
â—¦ Locate lower part of brake caliper housing - arrow - first.
â—¦ Install brake caliper with brake pads on wheel bearing housing.
The brake caliper lug - arrow - must be behind the wheel bearing housing guide.
â—¦ Secure brake caliper housing to brake carrier with both guide pins and tighten to 28 Nm
â—¦ Insert brake pad wear indicator connector into retainer on suspension strut (left side).
â—¦ Install wheels.
NOTE:
"¢ After each brake pad change firmly depress brake pedal several times with vehicle stationary, so the brake pads are properly seated in their normal operating position.
"¢ Check brake fluid level after changing brake pads.
Torque settings:
Guide pins to brake carrier 28 Nm
Sep 21, 2009 at 12:04 PM
