1999 Volkswagen Beetle mechanic can't figure it out
1999 VOLKSWAGEN BEETLE
112,000 MILES • 4 CYL • FWD • MANUAL
SHAKOKA
have my beetle in shop. They said it was fixed, before I got home it began to run rough when i stopped. I took it back ,it has been there a week and they can't figure it out. When you turn on anything electricall it makes the engine run rough. they believe it is a short somewhere but can't find it. Can you help? It did not do this before I took it there the first time. They replaced oxigen sensor, mass air fow sensor ,plugs and wires and tail light switch and headlight.
Apr 28, 2008 at 7:42 PM
MECHENGR
If everything electrical affects the way the engine runs, I would suspect a body to engine ground wire that is not making good electrical contact. If you can't find the ground wire, you can try running a new one.
Feb 15, 2009 at 1:31 PM
