I have just changed the front brake pads and rotors of my car and noticed that the front left wheel rattles as I drive. It gets progressively worse after driving a while. The vibrations stop when I brake which is why I thought of a brake pad problem. I can feel the vibrations under my feet as I drive. Also, the lug nuts loosen after a short drive so I have to stop and tighten them fairly often. I have tried jacking up the car and tightening the nuts. I checked the caliper bolts, they're tight. While I was changing the rotor I had to move the car having only changed the right rotor and pads. I then changed the other side.
Any help you could offer would be greatly appreciated. Thank you.
Sep 1, 2008 at 12:48 PM
