1999 Volkswagen Beetle Car won't start & remote won't u
1999 VOLKSWAGEN BEETLE
ERIKAKUHLMAN
Electrical problem
My remote will not open my door and when I manually opened the door it showed the security system light off & the car won't start.
Sep 20, 2010 at 8:10 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Thank You for the Donation.....
Do any lights come on? If not your battery is most likely dead. You will need to jump start it and I would also test the Alternator.
Sep 21, 2010 at 10:44 AM
ERIKAKUHLMAN
No, the lights will not come on, but it's a brand new battery that was installed a month ago.
Sep 22, 2010 at 8:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
It doesn't matter if the battery is only a month old, if you have a bad Alternator and/or a draw on the battery it will drain the battery to just about 0.
Have you tried jump starting it? If not please do so.
If it starts and runs fine then most likely you either have a bad (new) battery or a large electrical draw on the battery that drained the battery down.
To check for a battery draw you can use a test light or a volt meter. Remove either the Negative or the Positive battery cable. Then connect either the test light or the volt meter between the Battery Terminal and the Battery Cable. If test light comes on the you have a draw on the battery if using the volt meter and it shows more than 1.5 volts you have a draw on the battery.
Post results of tests....
Sep 22, 2010 at 10:09 PM
